I will be using Road mesh within foundation, steel within the void does seem over the top to me, my concern is movement of the base due to clay. if no trees r removed should I not worry about the Clay
The proposed foundations seem to me to be well over the top,
(unless there is something special about koi ponds I don't know).
I would normally expect a pond ,in clay soil particulaly, to be just a 'buyril' (?) liner fastened down at the edges by rocks and filled with water.
What is the thing with the huge thick base? (9") and rebo? that would be normal for a light engineering factory, but fishes???
Quite apart from the fact that life is too short.
It is well over the top, but if you are worried about movement on a clay site then only thinking of the base - especially as it's not going to be lined - is a waste of time, as any movement between wall and base is going to result in a leak or leaks.
Gotcha, shytalks,
I agree, the possible earth heave cannot be stopped by making the base thicker/heavier/reinforced, there would have to be clay board installed under somehow??
It jusy won't work.
So just dig it out, line it with a flexible propriety liner and fill, (not from the tap mind, so get saving that rainwater now.
Clayboard will do sfa under a raft. It's a void former, which biodegrades, so the raft would end up being held up by....air. Which won't work too well.
Blockwork on a slab, no liner is asking for leaks, regardless of subsoil.
Hi, shytalks,
Exactly, that's why I put a '?' about it.
Unless I'm missing something fundamental about ponds, whic are really just holes in the ground, then all this talk of concrete etc is ball-cocks
(to use a technical trade term)
The standard construction for proper koi ponds is conc slab with blockwork sides, liners are for goldfish ponds.
I have clay soil and used a 9" reinforced slab for the base, bars turned up the sides then hollow 9" conc blocks infilled with conctete. (Flat laid 100mm blocks are better if you have curves. )Then cast a ring beam around the top to rest the rockwork on. It's been in for 10yrs now with no leaks.
You will have to waterproof the blockwork in some way, I went for a rendered and fibreglassed finish.
