- Joined
- 28 Aug 2022
- Messages
- 2
- Reaction score
- 0
- Country
Hi would appreciate thoughts on how to go about approaching some foundations.
We are looking to build a small extension to the rear of our 1980's built end townhouse. Plan is a 3m x 3m extension built using a SIPs kit. I would like to get the foundations in so I can then get the exact dimensions to the SIP kit manufacturers.
Original thought was to sdo some concrete pads, build some brick piers and then use block and beam to create a solid base for the SIP kit. Today have been doing some investagory holes and have found a couple of issues. Firstly we have a shared drain that runs across the location of the extension, this is in good condition and is about 1.5m below the ground level.
Secondly, despite digging down about 4ft we have not been able to find solid ground.
If I understand right, building regs requires that the foundations extend down futher than the drain for it to span over. concious though that for a relatively light weight small extension this could lead to a lot digging and concrete so trying to consider other ideas.
Thoughts are the moment would be to use ground screws down to a depth lower than the drain, then use timber joinsts to create the base for the SIP kit. Not sure how receptive Bulding Control are to the use of ground screws though.
Further throughts appreciated!.
Thannks, Pete
Thannks, Pete
