This is really the most irritating job,
I'm fixing a bathroom basin to the wall and have drilled 8mm diameter using a tile drill. The problem is the wall is a stone cob wall, and I'm 200mm deep with an extra long masonry drill that I've bought specially, and after drilling for a 140mm deep frame fixings (8 x 140) I've come across NOTHING solid, the brackets for the unit are loose as hell. Even at 200mm deep, still feels like I'm not coming up against stone at all
What do I do? I can't increase the diameter of the screw because tile drills only seem to go to 8mm in diameter and then become holesaw like in design which will make it next to impossible to get an accurate hole, 2 for each bracket.
**** my life seriously
Here is configuration of wall:
8mm tile
12.5mm MR plasterboard
20mm line plaster
stone????????????????????
8mm tile
20mm line plaster
