Hi I have uPVC windows to install into a brick wall (replacing timber frames) - I assume you drill the holes into the uPVC window frame and then pre-drill a pilot through those holes into the brick work with the frame in place, then remove the frame and drill out the holes for the frame fixers. Is there any method for holding the frame in place whilst you pre-drill the pilots ?
