Hi, just a few questions as 3 months later i'm still doing my project!! Ok so when i started making the frames for my shed i used the "BUTT JOINT" technique. I had read that it was the easiest type of framing to do. I also read that a mitred joint is only a little stronger than than a butt joint hence me not going down the mitre route since i barley even know how to do a mitre!!
Anyway the problem i'm finding is that my frames don't feel solid at all!! I've used 2x2 and in each joint i've used a 100mm decking screw and 75mm galvanised nail. When the frame is fully made and you shake it and it still sways from side to side!!
I've been told to try and used triangular strengthning blocks in each corner but i can't find any!!! I've tried to make my own but to no avail!! It was also suggested that i use corner brackets but i tried one and it seemed that the bracket kept bending and not staying at 90degree angle!!
Any solutions??
Oh yes and one more thing that has extremely hampered my progress is that i'm working alone most of the time and have no one to help hold one piece of timber while i join the other. And this is causing me not to be able to join the pieces properly!! Any suggestions wat tool can help me out??
And finally how to i ensure that when i am joing my 2 pieces together, that i am joing them at 90 degrees??
Any solutions??
