Hi Guys, I've fitted a new monobloc tap with rigid tails (as supplied) to a Franke stainless steel kitchen sink + added a Franke tap support to the underside of the worktop and around the tails. I've also installed the Franke sink drains into position. A couple of things are bugging me before I install and connect up the worktop permanently:
1) The tails are installed ok but there is not much of a gap (despite a slight bend in the pipes) for connecting the Hep grey connectors, as the pipes finish at the same length and are quite close together. I'm scared of forcing them apart to put on the connectors and losing the seal at the tap end. Are there thinner pushfits I can use, or another solution?
2) I installed the sink drains according to the diagrams in the box with the metal drain straight onto the metal sink and the screwed black seal compressing tight from below. As I've never had a sink where a plumber didn't use plumbers Mait or similar between the sink and drain, are the instructions I used ok?
Thanks in advance for your help
