Franke
20 Nov 2006
Birmingham
I have a long neck leaking Franke mixer tap; it has no grub screw holding the neck, so how do I get this off to replace the washers?
I would say try turning it to the side and ease it back and forth it should come out.
Which Franke tap is it, if not sure have a look on www.franke.co.uk.
Cant remeber coming across a franke tap where removal of the spout becomes necessary unless its the spout that is leaking, most of them you have to access through the shroud that covers the tap gland.
