Free Standing Shower Enclosure
10 Feb 2007
Please can you advise where I can get a free standing shower enclosure, this is for a wet-room.
When I had the wet-room built for my mother in a wheelchair we had it designed so that water would not run down but unfortunately does.
Can I fit a wedge like they have in the swimming pool showers to stop water running down?
Any other ideas would be greatly appreciated.
Admin – Please move to the correct forum if it’s in the wrong one.
Your options depend on the floor construction and covering.
For example, I have a wetroom with Altro flooring. It's sculpted in such a way that the water stays where it's intended, but if it wasn't then I could cut the flooring, fit a barrier, and have a new piece of flooring patched in by an Altra fitter.
What floor and flooring do you have?
Thanks for your reply Softus,
I have a concrete floor with tiles.
In that case you can buy these units from most suppliers of plumbing products, for example B&Q and I assume you mean the following shower unit -:
If this is the case, it can be secured to almost every type of flooring. Especially a concrete, tiled floor.
Using only 2 inlets (hot and cold) and 1 waste these are very easy to fit also.
Thanks for your reply dmcplumbing,
But I do not want a shower base because of the wheelchair, I only need an enclosure and the water will run into the gully in the floor and any excess water needs to be contained by the free standing enclosure – Hope I’m making sense
