Hello,
My parents had a Wickes twin impeller, 3 Bar shower pump installed about 2 years ago. It's only used now and again when they have guests, and surprise surprise, has seized. When there's a call for water, it buzzes and gets warm but doesn't actually run. The showers "work", but the flow rate is pathetic.
It seems to be a rebadged Grundfos Amazon twin impeller STP-something and the helpline listed in the instructions takes you to the Grundfos help desk. They advised tapping the brass impeller housings at etiher side with a mallet while calling for water but this didn't do the trick.
What next, please? I'm a reasonably competent DIY plumber but don't want to drain everything down if possible. The gate valves are old and I'm not sure they work as well as they should.
Cheers.
Cheers.
