freeview picture freezing
11 Mar 2010
Manchester
I currently have two lcd tv's both with built in freeview. They are both connected to an old TV aerial via a signal booster in the loft. Problem with the main TV is that the picture will freeze just for a few seconds, this happens now and again and happens on all channels. The second TV, this is a 19 inch which i've just recently set up in the bedroom, Problem I've got with this one is that some freeview channels are missing and poor reception on all bbc channels. itv channel 4 and 5 are fine. Could it possibly be the aerial?
you can take a freeveiw tv/box from the same ariel source in different rooms in the house and get different results as in different channels in different rooms and different chanels every time you re-tune
pixilation is caused by weak signal an/or interference
check your local transmitter orientation
http://www.ukfree.tv/txlist.php
