Freezer gel packs - how do you dispose of yours?
11 Sep 2007
While I can perfectly understand the use of frozen gel packs with delivered frozen goods, disposal of them is not necessarily easy.
I have a septic tank which means that I can't just flush the contents of the packs down the drain and then put the plastic out with my recycling, so how do I deal with the gel inside the packs?
If they're what I think they are, I use them as freezer blocks.
What is the issue with a septic tank and gel packs. Is it just about the volume of water needed to flush them.
Along with everything else that isn’t obviously recyclable they go in to general waste or down the tip
That's a good question, I guess because of the gel there's is a danger of blocking up the soakaway?
My local tip is about a 40 minute drive from me. Putting the gel into the general waste is an option but there's a lot of them and due to the liquid these things are heavy when in any kind of quantity, the contents will also add a lot of bulk and there is a limit on how many black bags I can put out (three maximum once every three weeks).
Hand 'em back to the driver who delivers your next lot of shopping.
This isn't 'shopping' in the normal sense, it's frozen dog food (and I doubt if DHL will take back the boxes and gel packs. I can ask of course). Because of this I end up with about 36 gel packs every month .......... it's quite a recent thing though, the dog food supplier used to use their own chilled vans but due to a change in policy they now also use couriers (and so create a lot of cardboard, plastic and gel waste ......... ).
Keep 'em then (you don't have to keep them in the freezer, btw ;) )
You're gonna need them when it gets hot hot hot this summer :cool: (but you WILL have to have frozen them, for this bit) (y)
I'm running out of storage space .......
Get a big sack of working dog food, vat free.
Legally you have to take the dog to work with you afterwards
