Freezing condensate pipe advice please
23 Feb 2007
Gloucestershire
Like many, I had to deal with a frozen condensate pipe last year. My boiler and drain are both on an exposed north elevation so suffer extremes. Does it help much by lagging the condensate pipe? If not, I think my other option is to run the condensate pipe into the sink waste pipe, so it only has a downward run of 1m outside, I guess also lagging this. Can it still freeze in these circumstances?
The trick is to keep the condensate run to a minimum and if possible to keep it inside. Piping to kitchen waste is acceptable providing the regs are followed. See you MI's for guidance. Another thing to consider is heating the vulnerable pipe with proprietry devices, ie trace heaters.
If you can, run it internally to your kitchen sink waste.... Think about it, every time you use the sink, you will most likely use warm water and so de frost the pipe..... Only time this theory falls down is when the sink isn't used for a long time...
I'm changing my pipework from 22 to 32mm in the next few days. I was going to fit trace heating to the existing 22mm pipe but I couldn't find a suitable kit anywhere on the internet..... :rolleyes:
DO NOT GET A TRACEHEATER!
They are only useful for runs of 6mtrs or more.
You'd be best to insulate it using a waterproof insulation, such as ArmaFlex or fitting a product called Condensulate Xtreme.
Running it internally is fine, however, it's indirectly connected to your flue, so any problems could be dangerous.
I personally recommend removing the outside pipe, replacing it with 40mm and using Armaflex insulation.
OR paying BG £149 to replace the lot, with Condensulate Xtreme, and its all done for you.
40mm external pipe and a fairly steep incline I can say I haven't experienced
any problems with the installs I've done on that. Yorkshire area.
