I have partly installed a french door, and one of the doors is catching the bottom, and the other is catching the top.
I need to obviously toe and heel it but since I've never glazed before I'm in need of some direction.
This is my current line of thinking, please correct accordingly:
1. The left door that catches as the bottom, I should pack the bottom left (hinge)
2. The right door, I should pack the top left (where the locking mechanism is).
With that said, should I do the packing whilst the door is closed and locked or open ? I feel like doing it with the door open will be easier so I can get someone to lift the left door up as I pack it and pull down with the right door, but I don't want the glazing to fall out.
The panels are 1.8m x 0.65m and are triple glazed so quite heavy.
