Hi all,
I'm planning to install a perforated pipe/french drain system in my garden. There will probably be about 7 upstream endpoints, all draining into one pipe, then out through a wall into some wasteland.
Does anyone know if (and how) these are usually vented?
And whether/how you could use these vent points for access to clean out the pipes at some future point?
Planning to use membrane around the gravel, and possibly also a sock around the pipe, so this may not be a problem.
