About 2 years ago when the loft was built and a megaflow installed, I had my gravity CH system converted to a closed system. The boiler, a Worcester Bosch CBi24, remained as it was quite new and suitable for a closed system (the megaflow system came with with an expansion vessel of 8 litres). The radiators in the house were increased because of the loft to 20 in all.
The system was fine, but over that time I have had to use the filling loop to fill the system every now and again. This was to be expected as there was some air in the system which needed to be bleed out. But after 2 years I would have expected that almost all of the air would by now have been expelled from the system, but it seems that I have to fill up the system almost every 2-3 weeks or so. There does not seem to be any leaks as by now with the amount of water filled in that would have been obvious with damp patches appearing, but there are none.
I've noticed that the gauge, which should be at 1 bar, climbs when the heating is on and settles back to below 1 bar after a few days. Could the problem be that the expansion vessel is a bit small for the installation. The Heatrae engineer said this might be a possibility and that a vessel about twice the size should be installed instead. It that a reasonable possibility and could there be others. The system vents excess water in the system but I haven't noticed that as the pipe leads outside the house and not easy to observe.
