Fridge freezer trips rcd every 70 minutes?
17 Jun 2010
Cambridgeshire
help why is my fridge freezer tripping out the rcd every 70 minutes? repair man not coming till tues and it is very annoying
unplug it
pull it away from the wall
look at the dish that catches all the defrost water, it is on top of the motor. Is it so full that it is overflowing and letting water drip onto eletrical parts?
The more info you post the better you can be helped.
Make
Model
Product number (PNC, FD, PN, etc)
Serial number
Does this happen every 70 mins, have you checked the wiring to the compressor or the supply power lead.
Does it happen when the compressor switches on or when it is running or after a short time of running or when the compressor is off (or no matter what the compressor is doing)
Does it happen when the fridge has not been touched or a while after the door has been opened.
