Fridge light
25 Oct 2012
Dorset
Hi all
My fridge light stopped working so I did the obvious thing and replaced it but it still doesn't work. When I multimeter the lightbulb housing I get 9.5 ish volts which drop to 0v when the door close switch is made so I'm happy the switch works. Before I start pulling my fridge apart I just thought I'd check Should I be getting 9v at the bulb or should it be the 240v mains?
would
have thought 240v
is there any info on the old bulb as to volts? sometimes stamped on the
metal base of bulb next to wattage. or found in user manual
