Fridge that wont level
5 Dec 2019
Hope you are well.
I am renovating a property, they are keeping their freestanding fridge freezer. It is in good condition apart from the wheels and feet.
Floor is level but cant get the fridge to level out, it rocks, have adjusted the feet, there are only two adjustable on the front the rear has wheels.
I think the wheels are battered (square) which is why it wont level plus one of the feet doesn't screw or unscrew well.
Thinking of getting these to maybe bypass the feet/wheels and level it out.
What are peoples thoughts? what have you done in a situation like this?
Any help greatly appreciated.
The roller are unlikely to fit they are intended for fridges with 4 legs. I found with mine has to pack the rear wheel as there was not enough adjustment on the front unless the rear was already raised.
I've successfully used stuck together cut off pieces of self-adhesive floor tiles with enough layers stuck together to make the thickness needed. Since the floor tiles are about 1.5mm thick, you can make quite fine adjustments to the packing
