from a rose to spot lights
24 Feb 2003
i am currently fitting new lights in the kitchen i have took the rose off and am replacing it with spots on the spot light connection there are 3 wires but where the rose was there are 9, 3 of each(earth nuetral live) i know ive broken the link because the lights in the kitchen wont work which wires do i connect where? thx
oh dear.
You have a feed in, a feed out and a switch cable, unless you have a tester you will need to follow each cable to find the switch cable as this is the most confusing.
When you have found them see this
