I've checked my brakes against the minimum wear in the haynes manual.
I've got a 54 plate micra with vented discs.
Iv'e got 6mm on the pads. The manual says the min. for the pads is 2mm. is that a bit too thin?
Also checked the discs, which have about 1mm. before the minimun thickness mentioned in the manual.
Am i over reacting if i change the discs and pads now?
