Front door material
27 Apr 2009
Somerset
I'm hopefully having light oak effect uPVC windows and want a new front door as well. Was planning on having a matching composite door, but wouldn't mind a hardwood one. However, I'm getting very confused!
What's best - solid or engineered?
Can they be oiled - a lot of the sales blurb says not which doesn't make sense to me. I want to retain the natural colour/effect of the wood.
Or is a composite a better bet for a reliable fitting door?
And one website doesn't recommend their external doors be used externally unless protected by a canopy!
Any reason I can't put a vertical letterbox in a door with vertical grooves?
Ta.
Indeed - postage would be a bit high :)
Interested in pros and cons of the different materials, not styles.
Hi MJ, I to am after a new front door, I went into the shop below and they explained to me that a new solid oak door is approx 3 times the price of an engineered door.
http://www.cotswood-doors.co.uk/
I know it no-where near you but they should have all the info on their website you need.
Andy
Engineered will always be more stable and better, though sometimes depending on how they do it, the laminates may not match very well, not commonly an issue.
Oil finishes have a very short life and are not much of a sealer, they probably want them stained or painted for proper protection.
Personally I would get a UPVC door because they will never expand/contract in the cold and heat or if they get wet.
:eek: You are joking aren't you, worst things to have in the sun, expand, contract, crack, fade, warp, bow and if i knew how to put pictures up in a thread i'd show you plenty
