Front door not sealed
r_c
19 Jun 2016
I have read on this forum about using a piece of paper to check if a door is sealed, and it is quite clear that my front door is not sealing properly. (The draft on windy days also made it clear!) In fact it looks like the door is slightly bowed. The composite door was put in about 18 months ago by a Fensa registered installer who did all our windows at the same time.
Is this something that should be covered by Fensa's warranty? Should the installer be expected to investigate this (and possibly rectify it), or after 18 moths should I consider it out of warrant?
Should all be covered by warranty. Fensa won't be interested as they don't cover warranty work, they are just a Competent Person Scheme that ensures all proper Building regs etc are followed.
As goes the door sash , it could well be bowed , I have seen some of the dark woods Comp doors bow within a year , when south facing, especially with the continued heat we had last year. I bet your installer never told you to lift the handle up to completely close the door every time you go through it? This ensures the locking points are engaged and limits the amount a door can bow as it is fixed at top middle and bottom... I have had one supplier tell me in no uncertain terms that this is the reason they bow , lack of pulling the handle up, also the amount of times I speak to people and they say they have a draft , only to find out the handle hasn't been pulled up , thus engaging the compression as the door fully locks. The Comp door supplier will have tolerances for how much it is bowed before it is replaced under the warranty ( if it is indeed bowed as it may just need some adjustment)
Best bet contact the installer , if they are any good they will come and look and take the necessary actions
  • Thanks
Reactions: r_c
