- Joined
- 5 Feb 2006
- Messages
- 156
- Reaction score
- 0
- Country
Hi
We have an S plan system installed by BG some years ago. The boiler is in the garage and the pump and valves in the airing cupboard.
The boiler is "protected" by a pipe stat and frost stat. Today I got a chance to test it. With the system was off at the programmer and stone cold, I went into the garage. For the first time, I heard an audible click on the frost stat when I rotated the dial. I believe that meant the pipe stat had got cold enough to power the frost stat which I assume is wired in series.
However, turning the frost stat up and hearing the click had no effect whatsoever on the boiler. (Nor the pump or valves for that matter). The rest of the heating and HW system is working fine.
Does this mean it is likely the frost stat has been wired incorrectly? Its a long way from the garage to the airing cupboard and so maybe BG simply didn't connect it up to the junction box in the airing cupboard? I wonder if it could just be wired directly to the boiler since there are no places colder in the house that the flow/return in the garage?
Thanks in advance for any thoughts/advice.
