Not sure if I will explain this right but my garage is build front to back onto side of my house and the utility room is at the rear as a seperate room as part of my house.
Last year and this we have had a frozen pipe to the washing machine and I just thawed out the pipe with hair dryer.
The issue is the pipe is lagged in loft but where it goes down into the wall the lagging stop short and the pipe so close to eve that it pretty much taking the brunt of the -8 cold wind coming in.
Now the only solution I can think of is to either cut the lagging up and try get it hard up to the point it drops down the wall or for the 2 or 3 cm use some expanding foam to bridge the gap.
Wondering if you can tell Mr the best solution as I doubt I will ever get lagging to fully protect it but i guess I could re lag part of it and spray of foam to protect the hole it goes down.
