Hi
Frustrated with hot water cylinder! Have got a gledhill vented hot water cylinder with 22mm connections 50 gal tank in loft and vented y plan heating system. Problem is fitted rsp50 salamander pump with Surrey flange, when hot temp is cold the pump and taps run fine! But when it's heated to above warm air bubbles seem to be returning to the taps and pump making pump grumble! But when hot water cools all works fine . Vent all ok not sticking air cold feed down not blocked has anyone had this before?
Please help!
Jamie smith[/b]
Please help!
Jamie smith[/b]
