I hope I've not submitted this twice in the last few minutes. I so my sincere apologies.
I’m fitting my first alarm. It is a Premier 24 with 8 zones, two LCD remote keypads and I’m using Texecom Prestige QD PIRs. I'm intending to use EOL wiring. I’m sorry if I’m asking stupid questions but I have searched the manuals, instruction sheets, the forum and the internet without getting any clear understanding and I’m keen to learn.
My problem is that the PIRs have terminals marked FTA and RLED which I don't understand.
I gather that FTA offers an option of :-
(i) either having no LEDs on when the alarm is set but constantly lighting a LED if that particular PIR has been triggered once the alarm is unset. Chosen by connecting the terminal to Set Positive or
(ii) Causing the first PIR triggered to flash a LED (but still only after the system has been unset) if it is triggered and any other triggered PIRs, activated after the first, to light a LED permanently. Chosen by connecting the terminal to Alarm Positive.
So I assume that the alarm goes off. I unset it and look at LEDs to find which PIR has triggered the alarm first or which PIRs have been triggered at all. But may I take it that the LEDs mentioned are in the PIRs and not somewhere else – like in the control panel? And where are these Set Positive and Alarm Positive connections, please. I can’t see any connections labelled such in the remote keypads (which I hope to use to provide extra zones) or the control panel.
I hope to maintain enough zones, including those of the keypads, to have one for each PIR in which case may I take it that I may leave the FTA terminal disconnected? I would like to understand how to use it in any case.
The RLED terminal appears to offer the option of turning a remote LED on (it says 0V/NC) or LED off (It says 12V). Are these voltages those on the RLED terminal when the PIR has been triggered or do I need to connect the terminal to 0V or 12V? Where would this remote LED be? Do I need to fit one somewhere and run a wire from the RLED terminal with an appropriate resistor connected to the 12V supply? Is the RLED terminal related to the FTA terminal? And lastly, even though I'd like to understand it may I ignore this RLED terminal?
I would be pleased to receive any advice. Again sorry if it is trivial to you.
