hello folks, apologies for the length this is likely to be..
Ive got a full house renovation on my hands and i want to learn the hard way so currently doing floor to celing bathroom tiling and boxing...for the first time ever. I have tiled and grouted the floor as shown. I have large marble look ceramic wall tiles, looks smaller in the pics but they are 250mm x 400mm or 9.5"x16".
There are several issues im trying to get my head around. The first image is a rough sketch of the position of the suite and numbers for each wall.
[/img][/url]
okay..wall 1 is totally plasterboard as well as half of wall5 above radiator. wall 2 under window has lost some large amounts of plaster and has exposed brick in places and pipes on show below. Either side and inside of the window is what seems to be ply. wall 3 above bath position is in fairly decent condition with spots of wallpaper and artex over worn old plaster. wall 4 is the only wall i havnt ripped the tongue and groove off and is where the electric shower is. Im ripping this out and putting a hot pipe under the bath to link to new combi boiler with a new mixer shower.
radiator is fixed to tongue and groove and top haf of this wall is plasterboard. other pics show rough position of suite, however i am planning moving WHB away from the corner for more room away from WC. Also a rough sketch of shape of boxing, prob higher in reality to come above damaged plaster. the boxing will hopefully be moveable to access pipes
The questions are:-
1) I plan on using 6mm exterior ply to cover most of walls attached to battens. Would you see any problems in future if i coverd over the damaged plaster with the ply, more than likely with 2x1 battens to be safe or directly into the brickwork without battens and hope the wall plus will be good enough to hold it in?
2) I guess i cant tile directly onto plasterboard so will i have to use PVA bond/admix on top of existing plasterboard before tiling or can i get away with undercoat paint? If neither, should i cover the plasterboard with ply first to give it a batter base to attach to?
3)Im thinking this order. Fix ply to appropriate places, prepare ply with paint or pva, Tile wall1, wall2(inc behind bath position), wall3(above bath) , fit bath, fit WC, fit WHB, create boxing, tile boxing, position boxing, tile shower wall, fit new shower and pipes. Id rather tile first before fixing bath, people normally dont do this but im wondering why? can you see any other problems?
4)The pic which shows the suite, youll notice the WC inlet pipe doesnt go stright into WC as old one must have been differnt shape, im planning on getting some flexible pipe and maybe not boxing this? good idea/bad idea?
Again apologies for the size of this, im sure ive missed things out as well, probably issues relating to boxing position but not to worry.
thanks
Mike
[/img][/url]
The questions are:-
thanks
Mike
