We're having our water supply (spring to house) relaid in 32mm mdpe. The original supply was 1980's 1" alkathene but is being rerouted due to nearby building works. We occasionally get small frogs in the pipe so can't use liners in the fittings or screw-down stopcocks, as the fatter frogs get stuck with unpleasant consequences all round. We have a 32mm brass ball valve where the supply enters the house but no other stopcocks, so all maintenance is done live. That's no real problem as the pressure isn't high, but a stopcock at the source (and possibly where it enters our garden) would be handy in future.
We've used Philmac fittings in the past with great success. However their 32mm ball valves appear to have an internal diameter - the ball - of 20mm. The internal diameter of 32mm pipe is around 24mm, so that presents a problem. I could use a 1.25" FI to FI ball valve, and then adapt the MI to mdpe fittings back to 32mm, but this is bulky, rather naff and grossly expensive (£60).
Any other idea how to resolve this? Other makes of fittings?
