Full pannel to dwarf wall
23 Mar 2004
Kent
I have got hold of a full panel conservatory, very cheaply. I really wanted a dwarf walled on though. Can I cut off the bottom (up to the window frame) and then construct it as a dwarf conservatory (with wall).
I can not really see a problem, apart from the bar between the window and the panel below is not mitred in the same as a window would be, it is kind of block cut into the ends of the frame. All I would do it screw it up into the frame, mount it on the cill, as you would do with a dwarf wall conservatory.
Many thanks in advance.
Yes you can, anything is possible but take your time and don't rush it !
I've done this a few time and they're all difference !
