Hi all, some help required please!
We've moved and inherited an oil-fired heating system with two pumps (CH and DHW) but no zone valves. There is a cylinder stat but no room stat, so we would like to install a wireless room stat. But I've not come across a two pump system before (although I guess with two pumps the zone valve is not needed).
The current programmer is a Sangamo Choice PR2, two channel, set to 'gravity' instead of fully pumped and using only t3 (HW-ON) and t4 (CH-ON).
I would like to replace it with a Honeywell Sundial RF2 Pack 2, but not sure whether to set it as gravity (C-plan?) as per existing Sangamo, or fully pumped.
I'm told the previous owner fitted a Hive as a simple swap for the Sangamo and this worked but CH would not come on without DHW, so I guess the same might apply if I just swap in the Sundial? I could live with that, or maybe add a simple C/O relay at a later stage?
Many thanks
Many thanks
