Last year I fitted a Danfoss RET B-LS room thermostat. Since then it seems to have deteriorated. The hysteresis is so small that it switches itself off before the boiler has lit. Worse, it sometimes turns off a few seconds after the boiler has fired, followed by a continual round of short-cycling.
This isn't right, is it? What degree of overlap might you reasonably expect?
Also several segments on LCD display have faded, making it impossible to read. (Yes, I have replaced the batteries!)
I emailed Danfoss sales but have not had a reply. Don't want to slag them off completely - the rest of the control equipment is good.
It's just over a year since the stat was purchased so I guess it's out of warrantee. But this is not the sort of performance you would expect from an expensive bit of kit (v expensive compared with basic stats). Any suggestions?
