hello ladies and gentlemen, boys and girls.
Am currently having issues with a Vokera Procombi A 32.
After last weeks heavy rains and winds our boiler cut out, it turns out it was rainwater coming down the flue and had got the fan wet subsequently killing it in the process.
Had the fan replaced for new, rather than have it reconditioned/repaired as the guy who fixes them tells me that the repairs are not always successful and that recently guys had been bringing repaired fans back to the shop as they were breaking down again after being repaired.
Now the original fault on the boiler was no lcd display, and the fuse that I replaced was blowing straight away, in seconds.( the fuse is the 3.15amp fuse, thats after the incoming fuse spur but before the two on the pcb)
The flue was altered accordingly and re-weathered to hopefully prevent this problem happening again, also a plastic sheild was placed above the fan as a precautionary step incase water ever did get in again.
So fan fitted and everything working o.k.
After between 24-48 hours later the boiler cuts out again, same problem no lcd display.
So I check the fan fully expecting to have had water all over it, but there was`nt, it was completely dry. ( bearing in mind there was heavy wind and rain at the time )
So I check the same fuse and its blown, I replace that fuse and the boiler starts just fine.
But after a few hours the boiler cuts out again, same problem.
In my eyes it feels as if the guy from spares place has sold me a reconditioned fan and palmed it off as a new one, its broken down in the same time frame as the repair guy had said it would had it been repaired.
There are a few other mitigating circumstances that may or may not be relevant.
One time when the boiler blew a fuse it left a charred black sooty mark on what I believe to be the spark electrode( or possibly the condensate level sensor ) and on that particular ` blow ` it also seemed as though a lead that runs to the ignition transformer had soot markings on also ( a copper metal lead that has a clear pvc sheath along it )
Also probably unrelated but I had to re-pressurise the boiler probably 12 months ago and just recently the pressure seemed a little low, probably just over 0.5 bar maybe 0.75 bar.( when cold )
I would greatly appreciate any help. I take it my next step is to check polarity/resistance of the pump or fan perhaps?
P.s the pump seems to be working fine when the boiler is running.
Thanks people.
Thanks people.
