Fuse blown
apl
11 Oct 2008
Liverpool
Hi I have a Bosch WAE24177UK/01 washing machine & tonight the fuse blew on the plug so I replaced it and also checked the drain plug for blockages and on trying to put the machine back on it was beeping twice and wouldn’t do anything, any help would be greatly appreciated thanks.
Try removing the plug then switch back on and press start without holding the button down for too long. It could also be a faulty door latch or motor.
  • Thanks
Reactions: apl
Hi I’ve tried that thanks it’s under the stairs so I’m going to have to pull it out tonight & have a look at it cheers
Thanks tried that I’ve also tested motor, pump & heater. I know some have mentioned the door latch is there anyway I can test this thanks
Bought electrical door latch but before I fit it is there anything else I can check thanks for your help everyone
