I have a main fuse box in the cupboard under the stairs, and a seperate fuse box in the converted attic. The fuse in the main fuse box which appears to override the seperate one in the attic has tripped and will only switch back on if I turn the fuse box in the attic off. Then when I try to switch the attic fuse box back on, the under-stair fuse trips! Any ideas? Might one of the fuses in the attic have blown, or is it more serious? They are both fairly new plastic clip-in fuses.
