Have you much experience with domestic installations?
If your electrician is agreeable, it may be best for you to simply do the first fix, ie lifting floorboards, running cables, drilling holes, chasing plaster and fitting boxes. And leave him to do all the connections. After all, it's the electrician's name that will go on this work.
Leave the cable sizes for your electrician to decide, though lights will be a minimum of 1.0 mm, sockets a minimum of 2.5 mm. Shower and cooker usually 6.0 mm minimum. Here you will have to pay particular attention to the size of the load, in kW. A cable too small will severely limit your choice in shower/cooker. The cable route is important too, contact with loft insulation etc can influence the sizing of a cable.
10 mm earth cable to services like gas, water etc must be installed.
When burying cables in walls, safe cable zones must be observed, to avoid the cable being drilled through. In other words, if the cable is not in a safe zone, no one will know it is there, hidden.
Get the electrician to tell you where to drill holes in joists. Ask him what hole size is required. Fit all back boxes level, ie with a spirit level. Make sure they are at the same height.
Use oval conduit or capping to protect the cables when plastering.
Use rubber grommets on the entry holes of metal back boxes. It's difficult to fit them later.
Leave a little slack cable in floor voids near each accessory for any future alteration.
