Fuse in Consumer Unit
20 May 2005
One of our fuse wires (cartridge) in our old style consumer unit intermittently stops power going to three sockets. This can happen when a piece of equipment is switched on or sometimes without any external influence. When the fuse is touched it appears slightly loose and power is usually immediately restored. The fuse does not seem to have blown, as slight movement of the cartridge is usually all it takes to restore electricity. On the most recent occasion there was a small amount of smoke from the fuse, but power was still restored.
What would you recommend? Is there any immediate danger? I would appreciate any advice. Thanks.
you say there was smoke. this means something was burning and could cause a fire.
things to do:
1: turn off power by the main switch or external isolator
2: remove fuse
3: remove cover, exposing busbar
4: make sure the spring part is tightly together so itll good contact with fuseholder
5:check fuse for damage
6: put back together.
if problem continues, might be a good idea to call a spark
thanks andrew,
I took the fuse cartridge apart and the screws were loose
problem all sorted!!
Many thanks again!!!
