I have been on holiday for a month and so to avert flooding problems with frozen pipes drained the system and turned everything off.
On my return I refilled the rads and bled them. then ran the water for a little while.
the boiler pilot light is on (baxi bermuda 552). I put the control to water and heating (landis & gyr) and the boiler ignited and then a few seconds after heard the fuse blow that supplies everything (3 amp in a fixed fused spur).
I replaced the fuse and it blew again immediately.
1) is it possible to disengage the pump and see if that stops the problem, so at least i can get hot water by bypassing the programmer.
2) do you think this is the programmer or the pump? I cannot see anything else that it could be as there is no midway vale fitted.
Regards in advance
Peter
Regards in advance
Peter
