fuse location
17 Sep 2009
Aberdeen
The odometer or tripcounter up by the speedometer and rev counter has cut out due to messing around with the dials replacing dials with lockwoods ones.
It has check fuses 2 18 8 22 if have electric windows wipers at rear which do but are these the fuses located under the steering wheel or in the right side of engine bay which normally accomadates larger fuses.
It has f before all the fuse numbers, if the fuse if broken or gone it will be melted or fried the wire right.
So where are these located in peugeot 206 1.4 i 04 thanks.
