Just purchased an RF room thermostat kit to fit to my combi boiler, and not quite sure on the fusing involved.
The RF receiver connects to the 230V and 24V roomstat terminals on the boiler which I've identified in the boiler instructions, which is fine.
However the receiver specifies a 6A max fuse on the mains supply. Looking through the boiler installation instructions, the boiler apparently is supposed to use a 3A fuse on its mains supply (internally there's a 2A on the PCB also).
Would there be any problem if the receiver was covered by a 3A fuse instead of the 6A "max" it specifies?
I guess an alternative is to power the receiver off a separate fused mains socket / plug. I guess it doesn't have to connect to the boiler's 230V terminals. Although where do I get a 6A fuse anyway? Would a 5A do?
Just to complicate matters, I checked the mains fuse and discovered it's actually a 13A fuse in there! Surely this should be a 3A ?
p.s. if it's any use the boiler is an Industrie Fer Hawk II (yeah I know, you haven't heard of it. Few have! ).
