I have fed the conservatory via a fused spur from the kitchen ring main. The first double socket is wired in 2.5mm as is the ring, can I wire the 2nd and final socket in 1.5mm?
The 2 upstairs bedrooms (20m2 total area) are to be fed with a 2.5mm radial. Can the last socket in the run be in 1.5mm?
My cables cross at right angles at various points within the allowable zones, is this okay?
