After a bit of advise.. On Sunday the Boiler blew.
Boiler is an Ideal Classic FF350
Programmer is a Danfoss TP715
Junction unit is a Danfoss WB12
Water had been on, and running fine. Switched the heating on, and 10mins later there was an electrical bang from the kitchen where the boiler is mounted. This has blown the relay on the PCB for the fan, (new PCB arriving today). The PCB neon was not illuminating, so there was obviously no power reaching the boiler. A test with a multimeter confirmed this.
However, and this is what is confusing me, the boiler is not wired directly into the switched 3amp spur below it. The spur feeds the programmer, this then runs up the back wall of the kitchen, I assume to the junction box in the airing cupboard upstairs. The supply then returns and the boiler is connected using a terminal block to this ?
There is no power on this supply, feeding the boiler. There is power on the switched spur and the programmer is powering up fine.
There is no continuity on the live from the spur to the feed originally used for the boiler.
Why is the boiler not just connected directly to the switched spur ? (like the installation guide suggests) ?
What is stopping the live supply which was originally feeding the boiler ?
Any help would be appreciated as we are without heat and water at the moment !
(just to add - I have wired the boiler up to a 3pin plug directly and it powered up the board and ran for a short time).
