Hi
Can you run a tripple socket of a 13 amp fcu spur. As long as it doesnt run over the 13 amps this should be ok should it not. Would i be better running to double sockets from the Fcu Spur.
Providing you use the 13 amp fcu, fitting doubles would allow you a greater choice when choosing the design of sockets.
You can't get chrome triple sockets, for example, if you ever wanted to change them in the future.
And you would have an extra socket outlet to use.
