Hi hope you can help, my re wire is going well thanks to all your help on here, just a quicky though
I want to put wiring in for a cooker hood in the kitchen (obviously), an extractor fan in the bathroom and an outside light which will be switched from inside (without movement sensor)
Firstly, to spur off the ring main i have laid already, do i have to spur it from a socket outlet or can i chop into the cable before it reaches the socket, put a junction box in and spur it off that, the reason i ask is in the bathroom the closest socket is in the dining room below and the cable runs under the floor in the bathroom right under where i want to put the fan. is that ok? or can i run it off the upstairs lighting circuit?
Secondly, for the cooker hood, i haven't quite finished the ring in there yet so can i just go from the socket to the left of it, to a double pole switch, and then to the next socket. and from the double pole switch ( which has a neon light on ) to an unswitched socket behind the hood so i can just plug it in?
Thirdly, are outside lights mounted on walls ok to run from the downstairs lighting circuit? i'm not sure what the wattage is but its one of those bright ones! or will it need to be off the ring? i've used 1.5mm for the lighting circuit.
Thanks in advance
Thanks in advance
