Fused wall socket
25 Oct 2004
The socket to the kitchen fan extractor has a little red light to show when it is on.The socket is next to the fuse box and appears to be on a circuit of its own.
I have only recently notice but the red warning light is flickering quite a bit and I assume that it should be changed
I have a 13 amp fused plug which does not have a red warning on light (not really needed)which I intend to use.
Earth connections are pretty obvious but regarding the two cables from the fan unit do they go on to the 'load' or 'supply' connection on the plug.(I can then work out the others.)
Cheers
David
Err - plugs don't have Load and Supply terminals.
What have you got?
Sorry not making myself clear. Its not a plug as such but a socket to screw on the wall. On the front there is an on/off switch and a little compartment to pull out the fuse
The wiring to be completed to the back of the socket will have to be connected to N Load L Supply L Load L Supply together with 2 connectors for the earth wires
Hope this makes it clear(Not bright -as in brains-enough to relay picture
Cheers for help
David
What you have there is known as a fused connection unit (FCU for short). The cable which once went from the consumer unit to the old 'socket' should be connected to "Supply". The fan goes to "Load".
It sounds to me like your old 'plug' is itself an FCU but with a light in it. If this is the case, a flickering neon light is no big deal so there's no need to change the thing at all.
PS: If you do change it you'll need to fit the right sized fuse; probably 3 amp.
Hi
Great news if I don't need to change it because there is not a lot of cable to work with. My wife is convinced that the light has been flickering for the past 17 years so I guess she was right all along. I only noticed the situation yesteerday when I had to untrip a switch nearby.
Thanks for your help guys
David :D
