We've just had a gable end tiled and I was wondering if the roofer had finished it correctly or whether I will need to ask for changes.
It is tile on brick with a thin cement board between. The tiles are set on cement on the board but the board is straight on to the brick:
View media item 60832
The brickwork is fairly smooth but there are gaps (maybe 5 mm in places) between the board and bricks. The cement board and tiles project about 50mm proud of the brickwork.
Should the board have been set on mortar or a bead of sealer run down the join or is this normal practice and nothing to worry about?
