Hello,
First post to DIYnot, looking forward to learning as I refurbish my first property, a 1970's end of terrace.
Before purchasing the property last year I had a survey carried out separate to the HomeBuyers standard survey for my piece of mind. One of the points made was,
"The gable wall should be retrofitted with restraint straps, these should be fitted with softwood noggins between the rafters and ceiling joists, and timber wedges between the wall and first rafter/joist. The straps should be 30x5 ms taken over a min. 3 rafters/joists and be at 1.2m centres."
From my limited experience and from speaking to my surveyor I understand that this isn't a major job, but my question is does anyone have an idea as to the ballpark figure I should expect to pay to have this work completed, before I approach potential builders? Also, would this be likely a builder or specialist roofer job?
Thanks very much,
Thanks very much,
