Gainsboro power shower only runs cold
24 Apr 2011
Flintshire
Our Gainsboro power shower has started to run cold only, the 'power on' LED is lit at the switch but with the shower pushing water out turning the switch on then off then on doesn't effect the flow at all. The unit has been fine for 5 years. Any ideas greatly appreciated - Paul
I think, from memory, it's a 1050C; from memory only because the model name has been rubbed from the front. Is the model name under the cover too? if it is I'll whip it off, I'll whip it off anyway and get back to you - Paul
Nothing you can do with this shower as it is a sealed unit and the whole engine has to be changed.
If you remove the cover you'll see a black box that is the shower engine
they retail at about £65.
