gainsborough 1000x - no water flow
21 Apr 2009
London
gainsborough 1000x shower problem. The power is on red lights, etc. but there is no water flow at all... Any ideas?
faulty solenoid valve.
check its getting power
if power is their check for resistance with the mains power off.
should be about 3.4 ohms.
Hi, thanks appreciate the reply. I think you are right the Solenoid valve is gone. Is that something I could change myself? I can do electrical but not plumbing... Not sure if replacing it involves any water work?
Cheers
Great thanks, I'll give it a go (and try not to flood the place!!)
Cheers!
you'll be ok isolate the water feed to shower and elecy then they come out quite easy 1/2 hour job.
