I bought a house which has a Gainsborough 2000x electric shower already installed. Is there any way to tell what the kW rating is? I have no instruction manual.
In theory, yes - a like-for-like swap should be possible.
It would be sensible to check that the existing set-up meets current standards first though - ie. 10mm2 twin & earth cable, with suitable circuit protection - ask on the Electrics forum for advice.
You have to be registered to do electrical work in kitchens and bathrooms now though.
Actually - after looking at the pics in the following post, I would recommend getting advice from the professional guys on the Electrics forum before you do anything.
I'm a fairly competent DIYer, but don't want to be responsible for anything like that, through a bit of casual advice !!
