Gainsborough 9.5e shower water suddenly gone cold.
17 Jan 2013
West Midlands
Hi All.
I have a Gainsborough 9.5e electric shower. All of a sudden the water has gone cold.
I have opened it up and discovered a plunger next to the heater tank bit. This plunger operates a micro switch when pressed with a screwdriver. I presume it usually works via the water pressure, but it's not working now.
Any ideas.
Many thanks.
Ian.
Showers have a short life. Probably the heating element that's gone.
These are a sealed unit shower so no parts are available only a complete engine unit.
But if you are handy you can strip the inlet valve down on the bottom of the unit and there is a filter inside that blocks causing the pressure switch not to activate.
Otherwise it's a complete unit at approx £70.
Thanks guys. Thought it may have been a big problem. Got a new Triton Seville 9.5kW from Amazon. Not worth messing around with the old one, but thanks for your time.
